coal steam
Mike Kuntz
Member Posts: 4
I work for a heating company in Pa. I am trying to put a coal steam boiler back in service. The problem that I am having is with the draft control. It was a diafram unit that worked off of steam pressure. I took it apart and he gasket is shot. It has been suggested that I use an electric motor control and a aquastat. I am wondering if this is a good idea and if so what kind of aquastat to use. If you can give any advice I would appreciate it.
Controlling Coal Steam
I think you're on the right track. The Aquastat would be used to keep the fire from going out by maintaining a minimum boiler temperature. It would be connected in parallel with the room thermostat. I'm not sure what minimum temp to use but 120 degrees sounds like a place to start. Use whatever Aquastat can be mounted below the boiler's water line.
For your high limit, use a Pressuretrol on a one-pipe system or a Vaporstat on a Vapor system. And wire your low-water cutoff so it will cause the damper motor to close the inlet damper immediately if the level drops too low.
And post some pics!
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0
- 167 Indoor-Air Quality
