Steam Pipe Insulation
Scott Winkler
Member Posts: 1
Hi, I had asbestos removed and need to re-insulate the steam pipes in my basement. Is this a do-it-myself job? I already reinsulated the hot water pipes, but that was easy and off-the-shelf. The steam pipes are much bigger in diameter and much hotter. Where do I get the proper insulation? What is the proper insulation material. Thanks to anyone who can help.
STEAM PIPE INSULATION
This is a question oft asked on this site, Scott. Fiberglass insulation of at least 3/4" or better yet 1" thickness is advised for all piping above the water line of the boiler. You can do it yourself, but if you want it done right and have it look like a pro did it, hire one. Many times they can do it for about the same it will cost you to buy it. This insulation is not available in stores and must be purchased wholesale, so unless you know someone, it's not generally a DIY job.
Hello, my copper water pipe (before feeding the boiler and water heater) is very close, and in some places it "touches" the steam main. I can't visualize insulation wrapped around the steam pipe, because copper pipe so close. Can I just have the insulation wrapped around them both (together), or should I try to create some distance between the pipes before insulating?0 -
McMaster-Carr...
...has a lot of insulation suitable for steam pipes. Go to:
http://www.mcmaster.com
Search for "Urethane Pipe Insulation". You'll find quite a few options there.0
- 167 Indoor-Air Quality
