Broomell Trap - DF
Dan Foley
Member Posts: 1,268
I am looking for a 1/2" Broomell P trap for an old vapor system we are rebuilding. If anyone has a spare, please contact me (703-751-3288). If I cannot find one, I wonder what would happen if I used a standard thermostatic steam trap or inlet orifice instead? TIA
-DF
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=262&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
-DF
Radiator trap
I'd use a steam trap, I think. Not that an orifice wouldn't work, but the trap would be less confusing to the next serviceman in a house full of radiators with traps.
Noel0 -
Try Tunstall
I don't think these are on their site, but I remember Tom Tunstall saying he had some or could make them. Is this the messed-up Broomell you posted pics of recently?
If you can't find a Broomell water-seal, a standard trap like the Hoffman #17C should work fine. I'd prefer a trap on this system rather than an inlet orifice, since the trap stops the steam at the same place the water-seal does.
I believe a trap will pass more air than a water-seal fitting- you'll have to check this out. If so, and if the system has a very large radiator on it with a water seal, using the trap on the large rad may cure a sluggishness problem there.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0 -
Thanks for the suggestions. Yes, this is the same Broomell job I posted last week. I will post "after" photos when we are done. -DF
I've used
a regular steam trap with success!
regards,
Robert0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 163 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
