electric boilers and indirect water heaters
SM_2
Member Posts: 2
I missed some discussion on indirect water heaters I think.....Do Amptrol's have some kind of problem?
I would like recommendations on electric boilers and what is the most effecient way to configure an indirect water heater with radiant floor heat. Any ideas also on how much insulation is required under the floor if you are using a thin slab on top of subfloor?
Sorry for so many questions , but the heating season is nearing here in minnesota and I need to roll on this.0 -
Why a boiler for electric radiant?
If you are set on an electric heat source why don't you just heat the floor with a resistance blanket under what ever you can? Do you think you need the quicker response time holding all that water at temp would give? Are you going to use wood for the major water temp increase? I would price out both before I made the choice.0
- 167 Indoor-Air Quality
