Wanted: 6\" AL29 flue (PLEASE!)
kevin_5
Member Posts: 308
I've called everyone I can find, and talked with everyone, including "the good, the bad, and the ugly."
I did a web search and called SelKirk, Heat Fab, Exhausto, Able Distributors, all my local guys, and you'd think I was looking for the holy grail or an honest politician or something. I'm trying to bid a job and know 6" AL29 stainless won't be cheap and I don't want to guess. Can anyone please help? I would need approximately 70 total linear feet to run horizontally, with possibly a few 15 or 30 degree bends. NOTE: this is for 3 boilers, not one so don't panic. We would need an elbow for each one and whatever expansion joints, thimbles for 18" to 24" brick wall, we'd also need the end terminations etc... I've never used this stuff so I'm really in the dark. Thanks in advance, Kevin
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=270&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Kevin
Really none of my business, but have you checked with the manufacturer of these boilers to see if this is an approved venting method? I have never seen it done on the vent side of power vented or direct vented gas boilers. I have seen applications where approval was sought and granted for headering the intake air, but not the exhaust. Just curious.
Glenn Stanton
Burnham Hydronics0 -
Kevin,
Email me with the specifics of your request.
Harold0 -
No Problem Glenn
I appreciate your response. The fact I posted it here makes it your business as far as I'm concerned. I need to clarify I guess. We're talking 3 separate locations also. No headering involved. We're definately talking with the manufacturer on this. Thanks, Kevin
Thanks for the quick response Harold
I knew the right people were out there, I just had to wade through and find them. I'll email you. Thanks, Kevin
- 167 Indoor-Air Quality
