Proportional reset info
hot_rod
hot_rod Member Posts: 26,638
comes up often as we try different ways to mix more than one temperature. A good article, including limitations I hadn't thought of can be found at the Technical Corner at Siggys site www.hydronicpros.com
A very good read that cleared up some misconceptions for me! Excellent schematics also.
Also get the 1.02 update for your Hydronics Design Studio, while you are there.
Sounds like an injection mixing module may be added soon, also.
hot rod
