din rail
Earthfire
Member Posts: 543
Usually cheaper and easier to buy a box, the mounting plate and some din rail and make it up yourself. That way you get a box close to the size you need. Available at any electrical supply house or Grainger.
enclosure with din rail for tekmar relays
i am putting together a system with a few teckmar
relays - that are switching 110 as well as 24v,
so they need to be enclosed - the tekmar relay sockets
are designed to be snap mounted on a DIN rail -
am looking for an enclosure with a DIN rail,
the only company i found was: www.integraenclosures.com
anyone else? - thanks kal0 -
Yes
I agree- that's the only way to go..... or I can make you a custom box!!!!
grainger
thanks - i forgot about grainger - they are one of my regulars0
