backup power for gas boiler
Tim Gardner
Member Posts: 183
Very cool! Anything equivalent for oil?
A year ago, I adopted a 65 year old one pipe steam system on a somewhat old (not 65 years, maybe 30) Weil-McClain gas boiler. Problem is, the power often goes out in town during heavy snow. Obviously, this occurs when it is cold out, and when it would be nice to have heat.
Is there any way to get the boiler started and safely running during these power outages? Alternatively, is there any way to patch a battery backup into the low voltage lines running to the boiler and thermostat?0 -
computer UPS
Since it's a steam system, the power draw should be minimal. Measure the (fractional?) amp draw on the primary power. Size a UPS for the length of time you'd like to maintain that draw, and wire the boiler primary thru it.
Mark0 -
Besides the UPS
Another way is to convert to a powerpile valve and T86 power pile stat. This is the way alot of the old steamers were set up, if done by someone who understands powerpiles it's a good system that needs no 120v.0 -
The powerpile stuff looks very cool! Anything equivalent for oil?0 -
power supplies
one option is to convert your system to millivolt. Another option would be to buy yourself a deep cycle marine battery, a trickle charger, and a power inverter. Then wire your 24 volt transformer to a pigtail with a plug on it that you can move from a 110 volt outlet to your power inverter.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 109 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 966 Plumbing
- 385 Solar
- 15.3K Strictly Steam
