rookie primary secondary question
DanHolohan
Member, Moderator, Administrator Posts: 16,686
is to limit as much as possible the pressure drop in the common piping (that shared by the primary and secondary circuits) so it's best to have nothing between those two tees that leave the primary to go to the secondary.
Retired and loving it.
I know that in a primary secondary setup you should have your secondary tees around 4 times their diameter apart from each other off your primary circuit, but can you have another secondary circuit inbetween your tees? so it would be circuit 1 supply,circuit 2 supply,circuit 1 return,circuit 2 return. instead of cir 1 supply, cir 1 return, cir 2 supply, cir 2 return. would it make a difference if it was a one pipe or two pipe primary?0 -
wouldn't the second and third circuit
be receiving diluted temperatures? how would you compensate and which ones would be picked to be #1 #2 etc, just a thought??!
Murph'0 -
That always happens
in one-pipe pri/sec systems. You can get around it by using supply and return manifolds to the secondary circuits off a single supply/return hook-up to the primary circuit.Retired and loving it.0 -
Maybe this will help
I have taken the branches off opposite sides of the pipe, but never mixed the order as you questioned. What would be the advantage of that?
This article will clear up some of your questions,and if you are calculatorly inclined you can determine the temperature drop between the various tee take offs.
Highlight this link and paste it into you browser, click enter.
hot rod
P/S happy hydronicizing
http://www.pmmag.com/CDA/ArticleInformation/features/BNP__Features__Item/0,2379,11743,00.htmlBob "hot rod" Rohr
that looks like
how i did mine about ten years ago, manifold off of P/S and a secondary circuit0 -
that looks like
how i did mine about ten years ago, manifold off of P/S and a secondary circuit for radiant floor through a mixing valve (although later i questioned the manifold)mainly for the indirect and soon to be added BB and a few panels. i will post some pics after i clean-up a bit in the boiler room!! (G)Of course low bid caused a slight roof leak and my "me and Dan in the basement" certificate got wiped out, wonder if there are any re-prodctions available??
Murph'0 -
people always accuse
me of trying to sell stuff...guilty. We have been having really nice success with this product from Caleffi. (Check out the link). Siggy wrote and article about closely spaced tees in a box a few months back and we are all over it.
http://www.caleffi.com/en/index2.php?go=home.php
Michael Bleier
Able Distributors0 -
Say you used a manifold setup on the secondary circut to supply an indirect water heater and a number of baseboards. when the circulator for the indirect turned on would that cause heat to migrate into the baseboards? Would all the takeoffs on the manifold have to have zone valves even if they each had there own circulator?0 -
flow control
not zone valves, but rather flow control valves - and preferably on both supply and return for each "zone".
Mark0 -
DOUBLE BONUS!!
10 points for 2 new words to our hydronic lexicons. Hydronicizing and Calculatorly. Nice job HR:-)
However... I think I'd spell the calculator word with an i behind the r. Calculatorily (cow-Q-LA-toreally)
No points for word modifications ;-).
ME0 -
Link
hot rod ,
I'am having problems with your link ...sigh.....Is it correct.
Ed, the link
works at my end! Or go to www.pmmag.com. Click on the archive window in the yellow bar. Scroll down to Oct. 2000. Click on Siggys column.
Better yet buy this CD and get all the column 100 plus 350 color pages of text and diagrams.
Aaaaaand a hydronics 101 course to boot. Get 'em from the PM website.
hot rodBob "hot rod" Rohr
- 167 Indoor-Air Quality
