Dynatherm
DennisE
DennisE Member Posts: 4
I have a really old Dynatherm in my basement and I love how it works and heats my house. It is like 50 years old now and I want to get someone good to work on it. Does anyone know if they are still around or do you know anyone that could work on it for me? I am in Easton PA. They service tech I had come here told me to rip it out but I want to know for sure that I am going to be able to replace it with something as good as the Dynatherm. please help and thank you!
  • Murph'_4
    Murph'_4 Member Posts: 209
    type in your zip
    into find a contractor on the top of the side bar/pipe to the left. i think there are a few in your area, get in touch and tell them your concerns !! also contact dynatherm at www.dynathermboiler.com and speak with kerry moyer and he would be able to tell you of a dealer in your area !!tell him Murph' sent you, he'll get a kik out of that !!
    good luck
    Murph'
  • DennisE
    thanks murp your informaton helped me out alot! so why can't you come work on my boiler? Where are you located?
  • Earthfire
    Earthfire Member Posts: 543
    The Wall
    Dang Nab It!! THE WALL KNOWS!! And the guys at the supply house told me there is no repair parts available for them Old Bethlehem "Dynisors". Have about a dozen clients that still have them in their homes. I think that they are a very good water boiler. The only draw back is that the old original burners are intimidating to most "techs" that weren't around before 1970
  • DennisE
    Yeah they are still around. I called them the other day and spoke with Kerry, and he helped me out alot. He got me in touch with a service tech who is coming monday to check out my system. I have the origianl burner and Kerry told me that if I want to keep it he does have all the parts, but if I wanted to I could get a new burner and have the service tech install it. I was very impressed with Kerry. He helped me out ALOT. Thank you again Murp for pointing me in the right direction!
  • Murph'_4
    ahhhh so glad
    it worked out for you , at least so far!!
    Murph'
