Steam Conversion
Steamhead
Member Posts: 18,211
http://www.heatinghelp.com/newsletter.cfm?Id=22
Copy the above into your browser's URL window and it will take you there.
Now that that's done- if that's a one-pipe system he will need to run all new return lines. If it's two-pipe, the existing returns may be too small. The existing radiators may not be able to handle the heating load on hot-water. And if a tenant leaves a window open, a hot-water radiator will probably freeze and burst, but a steamer won't.
I'm not a fan of this type of conversion. If he's having system problems it's much easier and cheaper to fix them than to try to convert it. All heating systems need maintenance- even hot-water systems.
Where is this job located?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=157&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Consulting
Consulting
Converting Steam to Water
I can't remember where I saw it, but somebody wrote a "do's & don'ts" and "how to" on steam conversion to water. Can anybody help direct me. My customer has a small apartment building that he would like to convert to water and get away from the care and maintenance of steam.
Thanks, Mark0 -
Mark, listen to steamhead
- 167 Indoor-Air Quality
