Adding a Main Vent
Alan(CaliforniaRadiant)Forbes
Member Posts: 1,243
This is a job next to the Presidio in San Francisco. The system must have been slow to heat since there was no main vent.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=53&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
After
We tapped the pipe and added this vent.
Thanks for all your help Noel, Steamhead, et. al.
And
you looked like a genius to the owner, right?
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0 -
main vent
Can you tell me what kind of vent that is? Thanks0 -
That looks like a Hoffman #75
They don't paint them green anymore.
Consulting0 -
Hoffman #75
main vent although Steamhead told me to use a Gorton #2 because there is greater resistance on a 2" main than a larger main. So why didn't I use a Gorton? The Hoffman 75 "was all they had on the shelf". My face is red.
Owners don't know the difference since they just bought the house. It's one of those jobs where I haven't met the owners yet; I am only in communication with the GC and the AIA. There's a budget for steam boiler work and as long as I don't go over that amount and the system works, they're happy.
4 of those
equal one #2 Gorton. Nice job! It's great to see steam systems cared for.
Noel0 -
That's seriously bigger
Is is still ¾" pipe threads or larger?
1/2" MPT
Tap size
Does it matter what size tap is drilled? 1/2", 3/8" ? Lost Art says add T to ensure a very large opening to main vent. If vent opening on Hoffman 75 is a certain (small) size, why would you need to tap anything larger than that?? Just curious. Thanks.0 -
I've used smaller sizes
for the smaller vents and they work OK as long as you're not at the very end of the main. Alan had plenty of room to get his drill into the top of the pipe on this one, but this isn't always possible so going into the side and elbowing up works too. I have many vents in the Baltimore area installed this way, and have never lost one to water-hammer or anything else.
The ideal thing to do is cut and thread a tee into the main, as described in Lost Art. Unfortunately we can't always do that.
Consulting0
- 167 Indoor-Air Quality
