Someone from Burnham
of the boiler you are asking about is a PV83WT-TBWF and comes with a front mounted tankless heater, Taco circulator, water trim and controls and Beckett burner with cover. As John stated, the 1-1/2" supply is on the top left towards the front and 1-1/2" return is on the bottom front to right of burner. Hope this helps.
Glenn Stanton
Burnham Hydronics
  • nick z.
    nick z. Member Posts: 157
    Someone from Burnahm
    I know your Boilers are a fine product, its just that my most local supply house doesnt deal with you. I have a custmer that has requested a Burnham.Could you please tell me what the model no. is of a 3sect. with a coil oil fired unit is? Also where the feed and the supply are located, and size. I did go to your web site but my computer would not download the info. Thanx
  • John@Reliable_4
    John@Reliable_4 Member Posts: 101
    Burnham dealer might help.
    Nick, it would be a V-83. 11/2" supply is on left front and return is on bottom right either front or back. You can e-mail me and I can scan spec's for you. John@Reliable
  • nick z.
    V83
    Thanx Jon, thats all I need to know tofigure my fittings.
