Heatimer
This mix valve is driving me nuts. It looks like it does not want to work anymore. This mix valve is located on a Voyger making domestic and radiant. When there is a call for hot water at the shower it goes cold. I have removed it and soaked it in vinegar. Has anyone also had problems with this mix valve. Thanks Mike
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    just replace it...
    would it be quicker and easier to just ditch it for a sparco or taco 3 way? Is there a heat x-changer to seperate the domestic from the radiant? kpc
