Why I dislike di-electric unions... (ME)
Mark Eatherton1
Member Posts: 2,542
These are worth a few million. Cast iron flanges on Kent BTU meter, galvanized steel nipples and EPCO dielectric unions on 1-1/2" copper pipe. 25 years young.
ME
ME
dielectric unions
You should see the ones I took off a 40 gallon gas water heater the other day...talk about plugged!!! No maintenance on this unit whatsoever. No wonder it only lasted 4 years.
Have you ever found a dielectric union where the gasket lasted more than a few years, or better yet, survived being taken apart???
Yeah, but
look how clean the copper is, and from the photos apparently no degradation of the wall thickness (i.e. no electrolysis) which is really what we're trying to protect against with dielectrics, right?
Terry0 -
di-electric unions
What do you recommend when connecting disimiliar metals?0 -
Dielectric
Phil, I would recommend using dielectric nipples, such as victaulics #47,,,,,, Anvil,formerly Gruvlok has them, and there are others0 -
brass
think about it this way,,what are the valves made of on a steel piping system...the international plumbing code allows brass as a converter fitting from steel to copper....altho only some states operate under the ipc.0 -
Terry...
ELectrolysis always acts upon the lesser noble metal. If this were a true disimilar metal connection, the galvanized nipple, or the cast iron flange would deteriorate, not the copper.
I recommend the use of yellow brass nipples for eliminating any disimilar metal mixes in open, potable water systems. In closed loop oxygenless systems, they are not necessary and generally create more problems due to leaking gaskets etc..
ME0
- 110 Chimneys & Flues
- 981 Plumbing
- 387 Solar
