Steam Boiler Issue
L. Dorsey
L. Dorsey Member Posts: 2
If I have a cast iron steam boiler that is having a problem of short cycling (possibly related to the steam pressure), would decreasing the steam pressure resolve the problem even if its only traveling about 30 ft through pipe before reaching the heat exchanger?
  • probably not
    what is the size of the load; and what is the output of the boiler?
    Noel
