Snall Radiant Floor Job
Wayco Wayne
Wayco Wayne Member Posts: 615
radiant floor job. The room is 13 x 13. I installed RTI plates and pex tubing. It has hardwood floors. I was thinking of just using a thermostatic mixing valve run by a Danfoss MTD tstat in the room. It operates on air temp with a floor sensor that can be used to limit floor temp in this case to protect against overheating the hardwood floors. What brand of Thermostatic mixing valves do you guys use? What temperature ranges do you recommend?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=255&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
