check this out
The Latin Canadian
Member Posts: 16
WOW!!!!!!!!!!!!!!
who built that????
looks like someone is giving HB some competition!!!
Chris0 -
Where's...
the required damper?
Too bad you didn't get the chance to do some of that kind of work for us...
Nice job in any case. Hope who ever did it charged enough money for it!
ME0 -
re: damper ?
Damper is on back order.You can just see that the boiler on the right has a damper. I also wish I had the chance to do some of this work with you.
Noel0 -
Beautiful.
As nice as anything that has been put up for show here. Nice flow. Did you make that literature holder? If not, where did it come from?
hb
"Expert in Silent Warmth"
1-888-UB-COMFY
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"There was an error rendering this rich post.
giving credit where credit is due
I call it a rocket pocket.A guy named Joe Rocket showed me 10 years ago in Utah .Its a Toe kick deflector from your local HVAC supplier.Just bend back the edges and there you have it.You can even find them at home cheapo and Lowes.Thanks for the comment Heatboy.It means alot from you.0 -
I like the diamond plate, gives it a touch of class.0
- 167 Indoor-Air Quality
