2 Days left for this weeks deal!
Alan R. Mercurio
Member Posts: 588
This deal will be good until July 4th!<BR><SP><BR><b>The Informant 2</b><BR><SP><BR><IMG SRC="http://www.bacharach-inc.com/images/Informant.jpg"><BR><BR>The Informant2 leak detector allows pinpoint detection of both refrigerant and combustible gas leaks with the same instrument.<BR><BR> Its unique combination of state-of-the-art patented sensor technology, advanced software design and microprocessor controlled circuitry offers you unmatched precision coupled with tremendous speed. It is unquestionably the most sensitive, most reliable, most accurate leak detector on the market today. And the fastest.<BR><BR> Swap sensor tips within seconds and never worry about adjusting sensitivity levelsit's taken care of automaticallyeven where high levels of background vapors or refrigerants are present. The refrigerant sensor tip is finely tapered to 0.2 inch diameterso you can get in between coils and fittings, gaining access to hard to reach areas.<BR><BR> The Informant2 leak detector features an audible indicator with a mute option coupled with sequential LEDs to monitor increasing concentrations of refrigerant or combustible gases.<BR><BR>DUAL Deluxe Refrigerant/Combustible Informant 2 Detector Kit. Instrument comes with refrigerant and combustible gas sensors, color-coded sensor tips, protective rubber boot, MagLite®, instruction manual, 6 AA batteries, 5 filters, and custom soft carrying case all packaged in a hard carrying case.<BR><BR><BR>This unit from Oil Tech Talk Cost. $429.00 this includes <b>FREE Shipping & Handling</b> up to July 4t 2003. <BR>Please allow 4 to 6 weeks for delivery<BR><BR> <a
href="https://www.paypal.com/xclick/business=svsm98%
40aol.com&undefined_quantity=1&item_name= The Informant 2&item_number=001&amount=429.00&no_note=1¤cy_co
de=USD">Click here to place your order</a>
Your friend in the industry,<BR><BR>Alan R. Mercurio<BR><SP><BR><a href="http://disc.server.com/Indices/24736.html"> Oil Tech Talk</a>
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
