Plates with sleepers
Wayco Wayne
Wayco Wayne Member Posts: 615
with a carpenter on a radiant floor. I'm going to put rti plates on top on the sub floor with 7 inch wide sleepers in between the tube, on top of the flanges of the plates. Does any one have suggestions as to how to handle the U-turns at the end of each straightaway. Thanks in advance. WW
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=255&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
  • Dave H_2
    Dave H_2 Member Posts: 621
    On Top
    Wayne-
    This will depend upon the fihished floor covering. If you are using hardwood, just knock the corners off. It doesn't need to be exact as the strength of the hardwood for small crack will be able to handle the weight.
    The second choice is to router a 4" wide strip of plywood for your 8" on-center spacing. If using 3/8" PEX, use a 1/2" or 5/8" router. Again the neatness is not that imperative.
    If using a tile floor, the mastic will fill in the gaps.
    If using a carpeted floor, a thin 1/4" ply or luan would do the trick.
    Dave H.
    Dave Holdorf
    Taco, Inc
  • radiant
    radiant Member Posts: 20
    rehau
    Wayne, have you taken a look at the raupanel. you should check it out, it is what you are trying to accomplish already made for you with better heat transfer
  • JudeNY
    JudeNY Member Posts: 50
    I'm glad you asked. As a DIY I am doing the same thing and was afraid I was getting into something weird that maybe wouldn't work. I have heard you could put thinset in the curves to improve conduction to the finished floor.
    I will be doing from bottom up, slab, 1/2" foil faced isocyanurate, Thermofin-C, 7" wide (3/4") ply sleepers over the flanges, 3/4" wood finished floor.
    How are you going to nail the ply and flanges down to the slab ? I haven't figured that out yet.
  • Wayco Wayne
    Actually
    I am screwing the plates to the existing sub floor which is 3/4 plywood. Not sure how I would deal with a slab in this scenario. WW
