Mono-flo question
Paul Mitchell
Member Posts: 266
Going to add one radiator in a existing mono-flo system. One inch main line. Any issue on how long or short the distance between the tees have to be. Also side question...How come with mono-flo tees you can pipe into the bottom of each side of the radiator? I assume it is because of the preesure drop caused by the tee it will flow through the radiator.
Thanks
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=280&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Thanks
the tee's should be equal or more than the length of connected radiation.0
- 167 Indoor-Air Quality
