Indirect fired hot water heater
ronLD
Member Posts: 8
Phase 3 ,stainless steel domestic tank, steel outer tank.Lifetime on s.s. tank. go to www.triangletube.com
Indiect fired hot water heater
I am looking to purchase a indirect hot water heater. It should have a lifetime warranty, be under 46" tall (about 30 gallons), very efficient, for the least cost. What Brand is the best for the money out there? Is stainless steel best for the tank and coils?0 -
Mega Stor by Crown.........
would be my first choice if budget is the primary concern. No matter the cost of the tank, the installation of the tank will be the more expensive part. As far as a lifetime warranty goes, read the fine print. If the tank leaks in a few years, you will still have to pay for labor to replace it unless your contractor agreement states otherwise.
hb
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"There was an error rendering this rich post.
Thanks for your input0 -
See Heat Transfer Products Inc. www.htproducts.com
Superstore Ultra Indirects0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 391 Solar
- 55 Water Quality
