MacDuffco heat fins
Has anyone out there used the MacDuffco heat fins for under floor heating?
How do they work? Good, bad indifferent?
Are there any peculiarities in the system that I should be aware of?
Is the system cost effective, compared to staple-up or other systems of radiant heat?
Are the labor costs as reasonable as the manufacturer claims (1/2 that of staple-up)?
  • Ted_5
    Ted_5 Member Posts: 272
    Whats better? Cheaper to install or operate!
    Why do we in the US try to take radiant, wich should be designed to operate at lowest supply temps as possible to
    be the most efficiant as possible and figure out away to
    operated 180F. I don't get it!
    Ted
  • Mike Kraft
    Mike Kraft Member Posts: 406
    Give them what they want..............
    and they will pay$$$$$$$$$.........I could'nt agree more Ted.But it's all about the money!
    cheese
