Indirect fired hot water heater
ronLD
ronLD Member Posts: 8
Phase 3 ,stainless steel domestic tank, steel outer tank.Lifetime on s.s. tank. go to www.triangletube.com
  • Jim_17
    Jim_17 Member Posts: 8
    Indiect fired hot water heater
    I am looking to purchase a indirect hot water heater. It should have a lifetime warranty, be under 46" tall (about 30 gallons), very efficient, for the least cost. What Brand is the best for the money out there? Is stainless steel best for the tank and coils?
  • Jim_17
  • heatboy
    heatboy Member Posts: 1,468
    Mega Stor by Crown.........
    would be my first choice if budget is the primary concern. No matter the cost of the tank, the installation of the tank will be the more expensive part. As far as a lifetime warranty goes, read the fine print. If the tank leaks in a few years, you will still have to pay for labor to replace it unless your contractor agreement states otherwise.
    hb
  • Jim_17
    Thanks for your input
  • munchkin-man
    munchkin-man Member Posts: 247
    See Heat Transfer Products Inc. www.htproducts.com
    Superstore Ultra Indirects
