Base Ray
Have any of you Wet Heads heard of, or run across a product called Base Ray? It is baseboard heaters. Home owner wants us to use the old Base Ray we removed, to add an addition, to match the rest of the house. Unfortunately, after years of abuse it is in need of repair and some parts. Looking for someplace to get the parts. Thanks, Mike
  • RGresham
    RGresham Member Posts: 1
    Steamhead Member Posts: 18,205
    Burnham still makes BaseRay
    if you have trouble getting what you need, e-mail Glenn Stanton: gstanton@burnham.com . Glenn is a Wall regular and one of the best in the business.
    I'm not surprised the owner loves her BaseRay. It has all the comfort advantages of cast-iron without taking up the space that radiators do. If you've never experienced it, you're in for a treat.
    Consulting
  • Burnham BaseRay
    Mike,
    As Steamhead stated, we still manufacture Baseray cast iron baseboard. The thing you will need to determine is the height of what you have. Years ago it was available in 7" height. This has been long discontinued and is only available in it's current state of 9" height. Contact any Burnham distributor in your area with what you need and they will get it for you, provided it is not 7" height. Hope this helps.
    Glenn Stanton
    Burnham Hydronics
  • Burnham Base Ray
    Thank you gents for the info and also the speedy replies. I will check with our local Burnham distributor to see what can be done with what we have to work with. Thanks again. Mike
