Hoffman Rad vents
Dave DeFord
Member Posts: 119
My local supply house charges $ 20, and I'm not even in the trade. You might also want to check Gorton they seem to be cheaper ($13-16) and every one here raves about them.
Hoffman Radiator Vents
Need to buy some of these. Found one site that sells them and was planning to buy from them because it's convenient. Curious to know if this price is high/low/just about right. If the price is severely inflated, I'll find a local supply house. Have a look:
http://www.gogeisel.com/Catalog/hoffman_radiator_steam_vents_232717_products.htm
thanks.
pat0 -
I agree about the comments on the Gorton steam vents. I have found them to be much better than the Hoffman's. About $13-16 per Gorton vent is correct and is worth the money. Your local supply place should carry the Gorton's. There are different sized Gorton vents and speak to Ken Kunz at Gorton. His phone number is (908) 272-5881. He can tell you which sized vent goes on which radiator and he can probably direct you to your nearest supplier.0 -
Wrong phone number
Sorry. I gave you Ken's fax number by mistake. His phone number is (908) 276-1323.0
- 167 Indoor-Air Quality
