Teledyne Laars
Joannie
Member Posts: 98
Hi, Gary.
I work for Laars. Let me know if you need help from me.
Joannie
Joannie
Teledyne Laars
Does Teledyne Laars manufacture a boiler and hot water heater in one foot print?0 -
Teledyne Laars
sure do (gas only)
check out
www.laars.com0 -
Laars
Thank you for the help!0 -
The Monitor MZ25S meets
.......your request quite nicely and is wall hung.
Check out the website for more info www.mzboiler.com
Jack0 -
Combination boiler/DHW
We have good luck with the Burnham Minuteman 2.
Take a look at this product at:
www/burnham.com/residential/51160.cfm
I hope it helps, Greg.0 -
I've used both the combo units mentioned
and found they fell a bit short on the DHW production. Make the small sized indirect tank they come with will handle you needs. Otherwise they fill a nice niche!
hot rodBob "hot rod" Rohr
try an Endurance
I am WELL satisfied with all I've installed, and you can't run'em out of DHW ! Tank size isn't important, make-up speed is.0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
