Wirsbo-Quik Trak
chuck shaw
Member Posts: 584
I am pricing a job, homeowner is starting to get a jumpy about money. I thought I might try pricing 10" quik trac instead of 7". I figured I might save some tube and some labor costs for him. Everything will work according to Wirsbo's ADS. And at a significant savings. Has anyone used the 10", all I normally see is the 7". What, if any are the dissadvantages?
Thanks in advance for your help.
Chuck
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=143&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Chuck
Quick track
The only difference is the output.If your heatloss works go for it.The temperature difference between the tubes may be a little more,but I doubt it would be noticable.
Try the RAU-Panel by REHAU. I have used 2 times and works well. Good luck0
- 125 Chimneys & Flues
- 121 Geothermal
- 396 Solar
