towel warmer on recirc loop
paul lessard_3
Member Posts: 186
I place a bypass around the volume control which would be a fixed trickle of water to keep it all moving?
I consider all this only because If this lady takes her bath for 45 min and grabs anything but a hot towel the next thing she'll grab is a phone.
does any of this make sense?
thanks paul lessard... (;~])
towel warmer on domestic recirc loop
Anyone done one? Doable? Thanks!
I'm thinking of doing one with a volume control in the wall NM
Be careful...
you don't set up an amplifier for some bacterium, like Legionella P...
It'd probably be OK piped in series with hot going to the shower... When you take a shower, you warm your towels.
It wouldn't be a very productive space heater, but they rarely are, covered up with towels...What is the R value of a good Terry Cloth towel anyway...
Proceed with caution.
ME0 -
I did mine as the highest farthest element of a gravity DHW recirculation loop. It heats and works fine BUT there is that risk of Legionalla.
Could absolutely kick myself for not getting the oil-filled electric model.
Myson literature states that the rather common practice of hooking it up in series with a shower will never produce the warm, fluffy towels as intended. Of course the gravity flow is gentle, but it does take a long time to make the towels really fluffy.
I believe that in the UK they are commonly attached to ranges like Agas that are constantly "on".
Another option is to build a mini hydronic system (usually a very small electric heater) just for the warmer--service access, leak protection and equipment problems can make this difficult.0 -
Would it
rust?Retired and loving it.0 -
If you're talking to me...
and about the "dedicated mini hydronic system" believe that rust/corrosion might be the problem. (Don't quite understand "why" though in a closed system.) Supplier in KC MO told me that the little electric heaters they had been selling for the purpose died a VERY early death and he no longer recommended the method.
Myson warmers themselves are plated/powder coated brass/copper and have a very high working pressure and are rated for potable water use. Very well made and exceptionally finished but you certainly pay for the quality and importing.0
