Wirsbo Question
chuck shaw
Member Posts: 584
Can the Pro-mix 212 talk to a Tekmar 369 zone control? Anything I should know if I try to do this?
Thanks in advance
Chuck Shaw
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=143&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Thanks in advance
Chuck Shaw
RE369-212
Hi Chuck,
You can do this but only into one mixed channel per 369. You would go from Zo out+com to mix 1/mix 2 10K+com. Give me a call if you want to talk about what is is your trying to do.
Tim D.0
- 125 Chimneys & Flues
- 121 Geothermal
- 396 Solar
