Roth Multitherm
rick in Alaska
Member Posts: 1,514
Anyone have any experience with the Roth Multitherm manifold setup. Am looking at installing one, but am leery of the "high tech" nature of it. I want to make sure that it works like it is supposed to without any problems. This thing seems like a really nice setup for people like me who want to be able to do constant circulation with small zones.
Thanks for any replies, Rick in Alaska
soon. very soon
I am waiting for approvals for a Firehall in northern Alberta which will utilize these. Specs look interesting. But the tell-tale will be the on-site operation.
I've used the Roth tubing for some large dealerships in Edmonton, but have not yet had the pleasure of using the manifolds.
Let me know how it goes.
EIN
I havent used them my self but I did talk with a contractor from nothern ontario. He said he used them with the roth panels and the system was the best heating system he ever installed. And you can change the flooring at anytime because of the constant feed back via the sensor on the return loop. I have priced a few and waiting for the OK from the customers. Very interesting
Good luck if you need anymore info email me and I'll give you the contractor to talk with
Tom0
- 167 Indoor-Air Quality
