2 pipe air vent and one pipe steam
Angus Davison
Member Posts: 1
I recently purchased a 1906 Victorian with a steam system that consists of a mix of both 2-pipe/air vent radiators and one-pipe radiators. Some of both types are not heating up all the way across. I intend to replace all the radiator vents and possibly the main vents.
Anything that I should keep my eye out for, or suggestions. I've read up on it in "Lost Art of Steam Heating" and have a fairly good handle on the principle, but I always look to the field techs for the nay other important info.
Thanks in advance for your help!!!
Angus Davison
Angus Davison
They will only heat all the way across...
on the design day.
On steam systems, usually that was a below zero day, with the windows open part way. No Kidding.
Under other conditions, the thermostat satisfies before the whole radiator gets hot. That's the way it should work.
Noel
- 167 Indoor-Air Quality
