Fuel oil from turkeys!!
hot_rod
hot_rod Member Posts: 26,599
is being built not far from my home. I'm going to see if my local ASHRAE chapter can arrange a field trip to check it out.
Maybe I can score a barrel to try out:) If so, I'll need to bring out one of you oil experts to help me set up an oil fired boiler.
http://www.discover.com/may_03/gthere.html?article=featoil.html
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
  • John@Reliable_2
    John@Reliable_2 Member Posts: 104
    Time will tell if this ..............
    is to good to be true? I once worked for a company that turned rubbish into a powdered fuel.Spented allot of money and could make a product but never was able to market it to recoup ,they went out of business after about 10 years of R&D.Hopefully this has better results. John@Reliable
  • Jeff Lawrence_13
    Jeff Lawrence_13 Member Posts: 5
    Better watch out!
    HR, you better not get Ellen mad or you may wind up as '38 pounds of oil, 7 pounds of gas, and 7 pounds of minerals, as well as 123 pounds of sterilized water.'
    Stay on her good side!
  • PJO_2
    PJO_2 Member Posts: 36
    Now that...
    is cool! Gotta love the possibilities...
    Recycle and avoid foreign oil, at $15.00 a barrel? I sure hope it's not a fluke. And it all happened within an hour of me...
    Take Care, PJO
