Posting Pictures
Bryan_16
Member Posts: 262
Where do I findthe instructions on postingpictures to the wall? Took me 3years to do it, but I finally have something worthy of showing.
Bryan,
It is very simple at the bottom of the screen where you are going to post your picture click
then click on Browse. Find the file that you want to post0 -
Bryan,
then click on Browse. Find the file that you want to post click open. Then click the button that says add.0 -
Bryan,
then click on Browse. Find the file that you want to post click open. Then click the button that says add. Repeat the process if you have more pictures. Then click OK which will bring you back to your message and click post.
Hope this helps0 -
Bryan did you figure out how to post those pictures yet? If you need more detailed instructions let me know0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
