Tankless Water Heaters ie: www.astravan.com
Marian D-J
Marian D-J Member Posts: 2
Re: Gas "Tankless Water Heaters" Example www.astravan.com
"Bosch" Can & Would you Recommend? It's usage for our new home? We have 1400 sq ft. of 4 zone in 3" slab concrete and we have 1400 sq ft. zone in plywood using the "McDuff " System. We would like to add it for a 17' wading pool. We have 3 showers and 2 laundry rooms.
Sincerely,
Marian D-J
  • Marian D-J
    Tankless Water Heaters?
    Sincerely,
    Marian D-J
  • Mark J Strawcutter
    Mark J Strawcutter Member Posts: 625
    96 LS/AWD
    My '96 LS/AWD model has been pretty reliable. It did overheat once when the thermostat stuck. Don't think it would be suitable for domestic water heating.
    Wait, mine's an astrOvan. Never mind.
    Mark
  • Don_4
    Don_4 Member Posts: 41
    Bosch Heater
    These heaters are illegal to be used for hot water heating purposes in Manitoba. For domestic water needs, keep in mind the units on average will only supply enough hot water for one shower at a time.
