Teledyne Laars
Joannie
Joannie Member Posts: 98
Hi, Gary.
I work for Laars. Let me know if you need help from me.
Joannie
  • Gary_5
    Gary_5 Member Posts: 3
    Teledyne Laars
    Does Teledyne Laars manufacture a boiler and hot water heater in one foot print?
  • Gary_5
    Teledyne Laars
  • Joe_13
    Joe_13 Member Posts: 201
    sure do (gas only)
    check out
    www.laars.com
  • Gary_5
    Laars
    Thank you for the help!
  • Jack_5
    Jack_5 Member Posts: 7
    The Monitor MZ25S meets
    .......your request quite nicely and is wall hung.
    Check out the website for more info www.mzboiler.com
    Jack
  • GAverill_2
    GAverill_2 Member Posts: 20
    Combination boiler/DHW
    We have good luck with the Burnham Minuteman 2.
    Take a look at this product at:
    www/burnham.com/residential/51160.cfm
    I hope it helps, Greg.
    hot_rod Member Posts: 25,326
    I've used both the combo units mentioned
    and found they fell a bit short on the DHW production. Make the small sized indirect tank they come with will handle you needs. Otherwise they fill a nice niche!
    hot rod
  • Tony_8
    Tony_8 Member Posts: 608
    try an Endurance
    I am WELL satisfied with all I've installed, and you can't run'em out of DHW ! Tank size isn't important, make-up speed is.
