Wetstock 2 Photos (Steamhead)
Howard
Howard Member Posts: 57
I get a goofy face reflex when a camera is pointed at me and a blink reflex when the flash is about to go off.
Mark is showing a garden hose spigot and extrol tank pumped up to 70psi upstream of the pressure reducing valve. In conjunction with a Low Pressure CO, this setup will turn the dreaded waterfall call into just a no-heat.
Howard Hansen Service Technician Extraordinaire
