Honeywell controls information?
Ted Keane
Ted Keane Member Posts: 11
I'm working on boilers and furnaces,and I need a book that tells me what controls made by Honeywell replaces bad controls on units that I am troubleshooting.Does anyone know where I can get this?
  • John@Reliable
    John@Reliable Member Posts: 379
    Where to find?
    Your supply house should be able to help you. Honeywell has both a complete book and a cd-rom. John@Reliable
  • mike celiano
    mike celiano Member Posts: 6
    You also may want to try honeywell.com but probably the quickest result would be a local HVAC supply house.
    good luck!
  • BillW@honeywell
    BillW@honeywell Member Posts: 1,099
    Information
    You can go to http://hbctechlit.honeywell.com & download spec sheets on anything we have. In general, our universal controls like the S8610U1003 gas ignition module, the R7184U1020 oil primary, R8845U1004 switching relay and the L7124U1003 electronic aquastat will relpace just about anything out there. The new T8002C1000 programmable thermosts will replace any programmable on steam, hydronic or forced air. Ask your supply house for a Tradeline catalog, available as apaper copy or CDrom. Good luck, and thanks for using Honeywell products!
