Heat Link
Kritz_3
Member Posts: 85
Has anyone used their Stat Link manifolds/zone motorized valves?
Pro's/Con's would be appreciated.
Best system out there
in my opinion. The manifolds are great! The statLink is easy to install and gives the best controll of set point then any other system. It will hold set point at plus or minus a 1/2 of a degree! by modulating the flow with the zone valve. I have used them for 7 years and had great results!
Ted0 -
Thanks much Ted. Have a great weekend!
Steve0
- 167 Indoor-Air Quality
