time overide function
Jack_15
Jack_15 Member Posts: 12
Very interesting thought on the indirect. What control has the time overide function.
Thanks, from Jack..li
  • All tekmar controls
    have the ability to limit the run time for the DHW on priority. A person probably could also tie a time delay relay in to perform the same funciton on a DIY relay logic system.
    Give'm 45 minutes of dedicated priority max, then turn the hounds loose again.
    ME
