Basement Radiator Problem
Steve_16
Steve_16 Member Posts: 4
When I began to finish the basment, I was planning on putting in electrical baseboard heaters. A contractor, I hired to change the old heating pipes, suggested that I should heat the basement with rads. He roughed in 3 connections for the rads. Now that I've finished the basement, I have connected 3 rads up to the connections. However, I can't seem to get any heat. The system was an old gravity feed system, which was upgraded to a new boiler, and a circulating pump. The rest of the rads in the house seem to work fine. I've tried bleeding the system, but it seems as if the water just doesn't want to travel through these pipes.
Frankly, I'm stumped. Any help would be appreciated.
Regards
Steve
  • Mark Hunt
    Mark Hunt Member Posts: 4,908
    More info needed
    Did the contractor put the radiators on their own zone?
    How were they piped?
    Do you have any pictures of the system?
    Mark H
  • Steve_16
    Hi mark:
    No he didn't put them on their own zone. Basically what happend was: The original pipes were too low in the basement so they were replaced and as he replaced the old iron 1.5 inch pipes with 1 inch copper, he also added 3 new junctions for the new rads. The other rads on the line--the ones upstair seems to working fine. Basically there are 2 main feeds form the boiler. The one line used to feed 4 rads upstairs with branches from the main line. The contractor has now added 3 more junctions for the new rads. The pipes go up into the gap between the floor joists, and then come down at the wall where the rads have been attached.
    I don't have pictures, as the areas has been drywalled and all exposed pipes have been covered.
    Thanks you
    Regards
    Steve
  • Mark Hunt
    hmmmmmmmm
    well, without being able to see how he piped it we can only make guesses.
    Water is lazy and will seek the path of least resistence. The water is finding it easier to flow through the upstairs radiators and not through the basement radiators.
    If he ran the new copper pipes for the new radiators back to the mechanical room, you could put them on their own zone and circulator. If he just connected them to the system out in the finished area, you are going to have to open things up to make this repair.
    Hope this helps.
    Mark H
  • Eric
    Eric Member Posts: 95
    Air
    Did you get water when you bleed the system?
    "I've tried bleeding the system"
    Do you have automatic water makeup?
    How were the basement rad pipes isolated? I would isolate all radiators upstairs and see If you get water flow to basement, IE making your circ pump flow through basement.
    May need to balance upstairs and replace circulator with larger. But verify flow by closing upstairs first.
  • Steve_16
