Rheem Hot Air System
John Mills_3
John Mills_3 Member Posts: 221
model #?
  • MARK_21
    MARK_21 Member Posts: 19
    RHEEM HOT AIR SYSTEM FIRE BOX QUESTION
    Hello does anyone know where i can get a replacement fire box for my Rheem hot air system..Rheem told me its sold as a kit-heat exchanger and chamber--I dont need an exchanger! My beckett gun pops out in 2 minutes then the combustion chamber mounts with 6 nuts to the body of the rheem unit--Its so simple to take out--5 minutes... It has a few cracks in it--and would love to replace it.. I know about the wet paks but still would like a replacement.. Thanks for any help..
    MARK NY
  • MARK_21
    MY MODEL NUMBER RHEEM
    ROBC 084 QAAA
    Thanks
  • John Mills_3
    Appears to me
    looking at the parts list, that you need an upgrade kit to replace entire heat exchanger to a newer version. Ask a Rheem/Ruud supplier about
    RXOH-AU24A
  • MARK_21
    RHEEM
    So what you are saying is the combustion chamber isnt avail for my unit--only a kit..Thats strange! The exchanger is in mint condition...Like i had said-I clean my unit each year-this year i took out the chamber-which popped out in 5 mins and thought i'd replace it..Wow-a little 5 min job has to become a major deal-with a kit...
    Would you know anyone who would have a replacement chamber i could use-something that looks similar to what i have?
    Thanks for any help... Thanks..
    MARK
  • John Mills_3
    The parts list says
    the A model you need the kit to replace everything in sight. Once you get updated, if you need to replace individual components you can. Probably covered by warranty on the parts anyway.
