What IS THIS???
Steamhead
Member Posts: 18,205
many of us have never seen one of these things! I'm sure the Dead Men who designed and installed that system are smiling down on you........
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=157&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Consulting
Consulting
B&G Comfort Control Regulator Cat#72
I was on a job for something unrelated to this item but as a favorite speaker I know is found of saying there is more in the basement then just the boiler. So i was wandering and following pipes while the system ran up to tempature and :::sidenote-This is a 12 family unit with monoflo piping to the units:::: while following a main to see where it went I found an odd fitting piped in. It was a 90 degree fitting in a monoflo take off that had 2 1/8" tappings that were piped into this B&G control mounted approx 8' away up in the floor joists of the ceiling. The B&G comfort control regulator. Well it also was wired up with line voltage which was still live.
Its hard without a picture or diagram but let me see if I can describe it better.
Off of the main to a monoflo tee to this 90...then out the other side of the 90 to continue on its normal monoflo way then back to the return main via a return monoflo tee into the return. It gets strange at the 90 i mentioned. that has 2 1/8" lines coming out of it to this B&G control. I can only assume it regulates the flo through this monoflo circut in some way I dont understand as the odd 90 fitting is just a fitting...not a valve...
I am going to try to figure out a way to link a pic and diagram but for now thats all I can say about it as access to the living space was not available and i only got to look at this from the basement.
Scott0 -
I did narrow the patent number to the year 1954 or 55.
B&G Comfort Control Regulator Catalogue number 72
Scott0 -
Scott0 -
It's an early outdoor-reset controller
Here's how it fit into the system. This diagram shows a boiler with a bypass, but the Regulator could also be used to control the burner directly. In that case, the Comfort Control Valve and bypass were not used. Info from 1954 B&G Handbook.
The Handbook also has wiring diagrams. Tell me which controls are still there and I'll post the one you need.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0 -
Outstanding..Thank you...
Incredible....not only an answer but a picture as well...
I am going to slate some time to go back there and look further now because about 4 years ago the boiler was changed by a contractor and although the control is powered I am very very curious as to how it is wired in....
Thanks a ton for the info and I will post back what I find.
Scott0
