Recirculating hot water
Stef Davis
Member Posts: 11
I gotta bump this up because I do need to know.
Dana's answer didn't help
I am talking about potable water tubing-Vanguard. Its rated to about 180 degrees, so I can't see why recirculating hot water should have an effect on it.
Can someone enlighten me?
Stef
Stef
I know this is not heating, but I hope you can help me anyway.
Pex manufaacturers say their product is not to be used in recirculating hot water applications.
It is used in Hydronic applications.
What is the difference, and why not in recirc.?
Thanks
Stef0 -
Its not rated for use on potable (domestic) water.0 -
thanks for your response.
I was referring to the PEX which IS designated for potable water.0 -
recirc hot water with pex
I don't know why either, and have never heard that one before. We use it all the time. AquaPex is rated way over any conditions we see in a normal plumbing system. As always, when in doubt go to the manufacturer. They all have tech assistance numbers and help and answers are usually a phone call away.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
