Multiple Muchkins
munchkin-man
Member Posts: 247
The drawing you have prepared is fine. The drawing I am attaching is basicly the same but arranged differently. Check it out. You can e mail me directly at jeffc@htproducts.com Thanks Jeff
Multiple Muchkins
I have 5 Munchkin boilers I want to put on a primary loop to serve indirect water heaters for domestic HW and heating to fan coils. Each boiler will have its own primary pump pumping away from the boiler into a primary loop. The indirect water heaters will each have their own pump coming off the primary loop. There will be one secondary pump going to the fan coils.
Should I pipe up the Munchkins in series or parallel? Can someone have a look at the attached piping arrangement and give me your thoughts?0 -
Tom please find attached a drawing #2E
The drawing you have prepared is fine. The drawing I am attaching is basicly the same but arranged differently. Check it out. You can e mail me directly at jeffc@htproducts.com Thanks Jeff0 -
The drawing you have prepared is fine. Go to www.htproducts.com clik on Munchkin clik on installation manual see drawing number 2E. The drawing is basicly the same but arranged differently. Check it out. You can e mail me directly at jeffc@htproducts.com if you need me Thanks Jeff0
- 167 Indoor-Air Quality
