Vitodens question
Adam
Member Posts: 18
Does the Vitodens 200 comfortrol boiler control,
control a mixing valve??? Is it like a Vitotronic
200 control?? I have not used a Vitodens yet. I have
a job coming up,so i'm trying to learn as much as I can
about it...THANK YOU GUYS. AC
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=235&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
The control is the same as the Comfortrol from the RN series it will control high temp, low temp and domestic.
Mike0 -
The Vitodens
control is like the RN series Comfortrol. It will run up to (2)3-way mixing valves and a high-temp pump, as well as control the DHW setpoints.
vitodens pdf
this might help you
al0 -
Thank You
Thanks For The help. AC
- 167 Indoor-Air Quality
