cogged belts
What is the reason for the use of cogged belts over regular V-belts?
  • eddie grierson_3
    eddie grierson_3 Member Posts: 51
    Belts
    The main difference I have seen is they last longer.
  • Ray M_2
    Ray M_2 Member Posts: 64
    Belts
    There is less chance of the belts to glaze and slip.They are also rated for longer life.
    Ray M
  • Wayne_14
    Wayne_14 Member Posts: 39
    belts
    Generally used where small pulleys are involved, easy to bend
  • Wayne_14
    Cog Belts
    Energy saving cogged V-belts have been available a for a long time, but they are not in general use by manufacturers. Cogged V-belts have notches for added flexibility, so they require less horsepower and can be used on smaller sheaves for cost and space savings. The cog belts have a higher coefficient of friction over standard wrapped belts. This higher coefficient of friction allows for reduced slippage. Cogged V-belts also run cooler than wrapped belts, resulting in extended life. Vendors claim that energy savings of up to 4.7% can be achieved with replacement of standard V-belts with cogged V-belts
  • George, TES
    George, TES Member Posts: 2
    cogg belts
    They run cooler
