New Cast Iron Radiators
Paul_4
Member Posts: 7
Hello,
I'm working on a job that requires new hot water radiators, and we'd like to use wall-mounted cast iron. The only manufacturers that I am aware of are Burnham and Runtal. Burnham's Slenderized radiator is the correct style for this job, but they don't come without feet. The Runtal radiators are too modern for this old house. Does anyone know of a manufacturer that makes new, wall-mounted cast iron radiators. There are a large number of them, so odds are that I salvage yard wouldn't have enough to cover our needs. Thanks for your ideas.
Paul.
Paul.
We used to make
wall brackets for the Slenderized radiators Paul. The radiators would still have feet, but they are not in contact with the floor. I can check to see if these are still available if you would like. Hope this helps.
Glenn Stanton
Burnham Hydronics0 -
try Walney
radiators. They have the Victorian sytle ready for shipment.
Michael Bleier
Able Distributors0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 849 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
