ThermoFin and copper
hot_rod
Member Posts: 26,638
in the shop today. I'm working up some real time demos for my "Plate Debate" RPA presentation. Amazing how quickly the plates warm with the copper, from 62F to 130F in seconds!
hot rod
hot rod
What debate?
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"There was an error rendering this rich post.
Ken Secor
Is smiling if he's seeing this!!0 -
Was in Springfield
on business over the weekend. Wanted to look you up Sunday but had to rush out early before the big snow. Looks like it would have been a good time to come by.
Snow was about an hour behind me. Are you dug out yet?
Delta T
If that comes out anything like mine you'll likely find that as long as there is some decent mass (like plywood, cement board, tile) you can run a whopper of a delta t (relatively low flow) but the radiant surface won't vary NEARLY as much in temperature.
If you test insulated/uninsulated and high load (exposed)/low load (internal) be prepared for some surprises.0
- 167 Indoor-Air Quality
