wood/gas fired miniature boilers
> Hi there I have a question that you could possibly help with. I live
in
> Northern Canada and am very interested in finding a manufaturer of a small
> gas/wood/pellet fired hot water heater that would be suitable for heating
a
> concrete pad with piping in the cement. The size of a house or garage. A
> dual fuel unit, wood/pellets or when left unattended either elect. or nat.
> gas backed.
> Any help would be greatly appreciated.
> Thank You
> John Jeffries
  • John Jeffries
    John Jeffries Member Posts: 2
    Help with finding a gas/wood fired underfloor system
    in
    a
    > gas backed.
    > Thank You
    > John Jeffries
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    try looking ...
    at HS Tarm. They have a couple of good units...although probably not a unit that can do ALL three. kpc
    hot_rod Member Posts: 26,599
    Consider
    seperate units. I think Tarm offers a pellet fueled. There are plenty of gas, oil, LP, electric units that could be piped in for backup.
    Depends on how complicated you want to get. A simple electric water heater could be used for backup, depending on loads and codes!
    hot rod
